Steering Box
-83MONTESS-
4,570
967
Bellevue, Ohio
There was more than one im sure.
beermonkey9417
2,443
12
38
des plaines, il
if you look at like the SS montes and some of the 442 cuttys or the top of the line gbodys, they usualy have them. i did read a while ago that you might be able to swap the steering box from a formula trans am from around the same years iirc. do a search for "quick ratio steering" in the search section, you should be able to find something helpful.
DutchmanZ
14
The F- body box is a direct bolt on if you already have the o-ring style pressure line but you need the g-body pitman arm. It has internal steering stops that limit travel more than a G body quick ratio box. The regular boxes are either 14.4:1 or 17.5:1 where the quicker ratio is 12.7:1
