So my car will be using the complete drivetrain out of a 98 Camaro with a 3800/T5 and I'm trying to find a way to make the stock speedometer and tachometer to work with these two.
From what I understand, the stock speedometer is cable driven, but inside the speedometer the cable rotation is converted to a 4,000 pulse per mile signal that it uses to determine the car's speed. Has anybody ever tried to intercept this signal and input your own from the EFI speed sensor?
Will the tachometer work with an EFI computer system? I've heard the tachometers have a 6 cyl/ 8 cyl switch on the back of them. Is there a setting that would be accurate at all?
I'd rather not buy aftermarket gauges if I can avoid it because all of the other gauges should play nice with this setup.
