The newly fired engine in my wagon has a strange noise, sort of like a loud PS pump. It is there even with the serp belt off. I thought is could be the timing chain hitting the cast aluminum cover, but there is no hint of the noise listening to the cover. I plan on pulling the balancer off to make sure that is not it. I just remembered that I used a Jegs multi-position timing set that uses a thrust bearing.....anyone had any noise from one of those torrington bearings on a timing gear???
I would really rather not pull this thing out or even apart
Thanks
Brian
Thanks
Brian
