Stripped spark plug
I got mine from oreilly auto parts. If you decide to use a thread chaser make sure you get the correct one for your application. If you can get a small mirror and check the actual condition of the threads in the head..
If the chaser doesn't work, you will have to drill it and put in a helicoil. If you can't get to it with a drill, then you would have to take the head off and drill it or take it to a machine shop. I don't think Ive ever messed the threads up in an iron head.
just for the future put some bearing grease on the chaser to collect any metal shavings from falling in the cylinder.
