I have had a vibration somewhere in the drive line, not real bad but it's a nuisance. . It used to be at around 2100 rpm and you could feel it with the clutch in. The flywheel had been refaced but not balanced so I thought it could be that. I changed the flywheel with a virtually new one and the vibration was still there but at about 3100 rpm now. I was thinking it's probable the pressure plate and when I put it back on after changing the flywheel I probably changed the pressure plate's orientation. I have a new Hayes performance pressure plate and clutch to install this winter. The pressure plate was balanced the zero by the race team that was going to use that set up and I thought that will solve the vibration
Something happened the other day that throws my theory in the garbage. My intake is leaking a bit of oil into a couple of cylinders so I have to top the oil up every once on a while. I have new gaskets to install this winter. A friend was topping up my oil and he managed to over fill it by about a litre (close to a quart). I was not too worried cause I'm not planning to run the car hard and am parking it real soon for the winter. With that extra oil the vibration almost went away. The dipstick in my car shows the right level. I have a 7 quart pan and with the filter 8 quarts shows the stick as full. My oil pressure is perfect. I talked to a friend who has been building engines for years and owns a speed shop. He has no clue what it could be. I'm wondering if any of you guys have come across an issue like this.....thanks for reading and hopefully someone here has the answer.
