84regal17 said:is it possible to supercharge my 4.1 v6 and where can i buy the supercharger and also whats the biggest cam i can put in my motor without having to redo the heads and whats a good brand thank you for your help
megaladon6 said:centrifigal will always work. check out companies like Vortec, banks, paxton...
but they aren't going to be bolt in and go. there's oil delivery, fuel and spark tune/mapping, intercooling, plumbing, etc. and the extra power may blow the engine if it's not rebuilt for it. but a supercharger is easier than a turbo.
madmaxstyle said:on top of the all mighty GN, Buick also put a supercharger on the 3.8.
Available in 90's Park Avenue Ultra for sure
as well as the 90's Pontiac Bonneville SSEI
quote]
those were front drivers, but would the s/c still mount to the rwd 3.8?( just thinking on to the next abandoned project )
Actually, that's the 4.3 you're thinking about; the 3.8 is the Buick V6, totally different design...still a very strong motor though.I know for a fact the 3.8 is bulletproof its just a 350 with 2 cylinders lobbed off.
Sadly, no, not without a lot of aluminum welding skill. I've seen a 4th gen F-body somewhere that it was done, but the guy had to cut where the throttle body mounts and turn it 180 degrees.(EDIT: Found the link. You have to be a member of the site to see the entire thread, but the OP's avatar shows what he did to make it work)those were front drivers, but would the s/c still mount to the rwd 3.8?
