Well since the 700r4 that was mounted to the olds 350 that's in my 442 is gone, it is now time to start doing the manual swap. The main reason I'm posting this is because I need some help, Id like to know what the easiest clutch pedal assembly to use is. That is really the main thing, but id also like to hear anything you guys would like to suggest if you have experience in this swap. Such as pilot bearings on an olds 350 crank, any machining that should be done, bolt patterns and mounting of the shifter. Thanks for your help guys.
