Just a quick intro, My name is T Mack im from Detroit Michigan I own a 1987 Buick Grand National G Body with 25K original miles...
Im here because i was loking for some info and or help!!! :?:
I put a set of 20" Foose Wheels on my car and the fronts were rubbing when i hit big bumps....
I could not figure what to do so i ended up putting 1" spacers under the front coil springs and that fixed the problem....
the problem is i got wy more than a 1" lift its almost 2" and thats to much... Will it settle down some do you think?
Also i was wondering if i should do the same to the rear to make it sit even. Thx in advance... 😀
Has anyone else used these rubber 1" spacers??? :?:
