Great posts guys! Your definitely swaying me in that direction...
I did some rear seat bracing to the car but will probably do more.
I actually uses 18ga sheetmetal and completely filled in the opening between the passenger compartment and trunk:
Then on the back side I welded in a cross brace similar to the above cross bracing. But like I said, I may add some of the bolt in cross bracing as well just to be safe.
We also had to replace my entire trunk floor with a another from a donor vehicle. When that was done, it really strengthened the body since we welded all the seams of the trunk floor. It was amazing how much that helped compared to the way the factory did it with just a few spot welds.
Blake pretty much hit it on the head how I'd plan to do this. The easiest thing to do is cut the roof at the A,B and C, pillars. I can tell you right now its would be EXTREMELY tough to cut out just the center section of the T-Tops and go that route. Welding on the middle of a roof panel is virtually impossible! I had decided I was going to fill my sunroof opening in back when I had my car on the rotisserie. I bought a roof section from another car and traced the opening out onto it. Then started tacking everything into place.
By the time I had a few tacks in place I had already warped the roof around the sunroof opening! And I didn't have a whole lot of heat into it.
Oh, I have another Pro: Less headliner!
