I’ll look at this week, is it hard to remove the gauge cluster ?It's probably your jumper bar. I had the same problem .You can remove the jumper and solder in a piece of wire in its place .
Not at all . take all the screws out and pull it straight out just enough to reach in and unhook the speedometer cable .I’ll look at this week, is it hard to remove the gauge cluster ?
Thank you for the info !Not at all . take all the screws out and pull it straight out just enough to reach in and unhook the speedometer cable .
11rc ? ,will check wireIIRC chevy tach's don't have the 6/8 cyl. jumpers like olds/pontiac. they're different circuit boards. check the wire from the distributor to the firewall. maybe it came loose or something chewed it in two... start there.
