ok ... so backup lights, brake lights, and blinkers work ... but no taillights just when driving. think it's a fuse or the bulb? isn't the brake bulb the same as the taillight bulb?
dudeface said:need a high low bulb........running, then brighter when you brake
1157 is the bulb number..........sounds like your useing 1156 bulb
Thanks I'll give it a try in the morning and see if it works.Da Reazon said:There is typically a ground wire in the rear harness somewhere that goes bad when this happens so look for your rear light harness grounds and check them for rust or corrosion and if there is any clean then and cover them with the gel you put on your battery terminals to keep corrosion away.
