It's hot, and I live in Florida and deliver pizza full time. In the summer, the average high temperature is around 93 degrees with 90% humidity and a heat index of 110. The problem is, my truck has an issue with it's ECU where it turns the A/C compressor off the moment the engine starts and on the moment the key is turned to the off position. I have traced it back to the ECU using a factory service manual and all roads point to the computer. Until now, my solution has been to run it off a relay that shuts off when the engine is off, and has a binary switch that interrupts the circuit should the pressure be too high or low. Sadly though, this let the compressor run constant and while I tried to make it last longer by lowering the amount of refrigerant, the compressor clutch is now just about fried. I can't afford to fix it the right way either as I just drained my bank account to fix the critical problems with the truck and fix the roof on my house. Plus, I am going into the slow season and won't be making much money for the next 3-4 months. It also has 344,600 miles on it, and I don't know how much longer it will last ( could be 200k or 200 miles). So, my solution then is to ride out the summer by running a set screw through the front plate of the compressor clutch to lock it to the pulley. This way I can undo it when it cools down outside and I won't be making a permanent change to the truck. So, is this a bad idea?
