Testing an electric fan
That is what I thought... Where the 3 wire connector connects to the fan is labeled. The Black wire is labeled "neg" with a fused line and the Brown/orange is labeled "pos" and is not hooked up to anything. The middle wire blue is not labeled but fused.
So the only 2 wires used are fused which confuses me. I guess I need to retry testing the fan to make sure it works then try to figure out the wiring
One concept that was hard for me to originally wrap my head around, is that you can effectively put the fuse on either side of a circuit and have it blow when it exceeds the rating. However, it is much easier to control the positive in a vehicle since most of the chassis is grounded anyway.
I'd just use a battery charger as mentioned above. That's how I test out trolling motors, etc.
Ok, I tested with a battery, how do you use a battery charger?
Thanks 83hurst/olds!
The fan works and it is a two speed. :banana: The PO only had it hooked up to one speed and it was the slowest. So does anyone know if the fan runs speed 1 seperate from speed two or conjunction with each other? Also how do you hook it up to run both? I would like it to come on when it comes up to temp. and then high with the A/c kicks in and/or if it gets to hot? Is this possible or am I asking to much? 😳
It looks like you should be able to do that using the wiring diagram above. I can't think of any off the top of my head that requires both leads to be hot for the 2nd speed, although I also can't think of it actually hurting anything either. Your second speed would effectively tie into the lead on the AC compressor. I would use a relay though for ease and safety sakes.
