ok the trans in the t-top is doin funny sh*t and i gotta sort it out before thunder.
trans is a TH350 with stage 2 shift kit.
only when the trans is warmed up (cruise around town and a few hard pulls) ill be putting along in 3rd with VERY minimal throttle, just enough to hold speed and it randomly drops to 2nd but not fully. if you give it gas after it drops it pulls as it would in 2nd but if you let off it drops to a idle. manualy shift it down to 2nd while doing this and it goes into 2nd normaly, gives you good hard acceleration and deceleration. i made sure there was a good seal on all the vacume lines going to the vacume modulator and the kickdown cable is adjusted properly and the fluid is well within the operating range with car level idleing in park with the trans warm.
any idea whats doing this? faulty vacume modulator?
