Ok so a while back I pulled out of my shop and all of a sudden no forward gears only reverse.
Yesterday I was under the car and I saw the vacuum line to the modulator was off. Now when I first have this problem I aded atf and it poured out just as fast as I put it in. I plugged the line back up but didn't have a lot of fuel& it's set for a while and it is cold so couldn't get it running long enough to try to put in gear but could this be the problem...The line being off of the modulator as now no fluid is leaking. I will be putting gas in it in a few days and jumping it for for the extra juice to try to get her going & see if she goes in gear.When this first happened I had only reverse.Does that mean anything with the line being off the modulator? Thanks
