ThA RuNt projeck "FRAME OFF"
Re: 81' malibu BKA "Tha Runt" updated 2/2/12
kuruption109 said:
Bumpin1ohmSS said:
SWEEET!!!!!
Elco Warren
80 UP!
what do those rear disc conversion cost?
The rotors? They were $85. The calipers and backing plates cost you need to hit Skip up on that. But you pull parts also so you kinda know the general cost of the parts...
Someone has been a busy boy... :lol: Glad to see that you haven't given up on it. I guess you weren't able to extract that bolt yet, huh?
Pontiacgp (Steve), had a good suggestion about hitting the bolt up with a hammer to dimple the spot where to cut a door or hole. A hole cutter would be another option you could use. Just make the hole large enough to gain access to the spinning caged nut.
or maybe i can tack weld the caged nut in 2 spots the lube it and get the bolt out?
That might be worth a shot. BTW, you have a nice clean frame there. The benefit of an Arizona car...little to no rust.
Keep up the good work. :wink:
