I'm just getting into the '87 El Camino project. Doing small items until I can move it to the shop, for the major work. ( if it ever quits snowing & raining here for a while )
The center console between the bucket seats appears that people had been sitting on it, which left a lot of cracks in the plastic around the cover for it's compartment.
I'm reinforcing it on the inside with aircraft aluminum sheet stock. The vinyl top on the compartment cover has shrunk a bit, and I'll have to heat it with the heat gun to make it pliable & stretch it to the size it's
suppose to be, to get it back on the lid parts.
It also needs a hinge on the cover. Original bendable plastic hinge ( another GM bad idea) failed like expected. I'm gonna use a mil-spec aluminum hinge in place of the trashed plastic hinge, which I hope will do OK...
