The Junkyard Interchange and Rarities Thread
clean8485
2,860
2,135
Ontario, Canada
Dropping some of my interchanges
04-06 Vue mirror
W body buckets and rear seat are really close. These are out of a 94 cutlass. Good option if you want power seats and have a split bench but can't find G body bucket tracks.
Rear seat folds down.
Rear seat upper cushion needs some brackets up top to latch into the G body hooks
Lower cushion gets a small tab.
Front seats get a small bracket on the rear
Front bracket on front seats just need a hole slotted
84-88 fiero or Fbird steering wheels are the same as GP wheels, just have to swap the bracket/standoff.
For T5/T56 people
You can buy repop shifter boot leather pre-stitched online from a 4th gen F body. Cut the center out of the shifter plate and glue leather to the G body plate.
Thank you for sharing this info. The seats look really good, and I like how the rear seat folds. What size of metal channel did you use on the rear legs of the front seats?
81cutlass
4,639
13,542
Western MN
1.5x3 if I recall correctly
87National
661
679
eastern SD
Do you happen to know if the later W-body seats (97-03 2 door grand prixs, monte carlos, etc) mount the same as these cutlass seats?
81cutlass
4,639
13,542
Western MN
Not sure. I have seen people run the later W seats but I don't know about brackets.
Rodknok
210
577
Just finished a 19 page read lots of good information. My take aways for my next junkyard crawl
-Xj jeep steering shaft
-98-02 blazer 2wd brakes
-98ish dodge Intrepid radiator fans
-Trailblazer 2wd alum driveshaft
86LK
1,937
1,986
correction: that would be a 98-2005 4dr 4x2 blazer, are you pulling the rear disc also
81cutlass
4,639
13,542
Western MN
Thought I'd add my Vue Gentex mirror was only showing East or SE. I looked and there is a calibration procedure you need to do for it to read correctly.
You need to set the magnetic geographic zone & enter calibration mode and drive in a small circle at 5 mph until it exits cal mode.
It's easy but didn't see calibration mode mentioned anywhere.
  • Useful
78Delta88
1,250
1,015
SW Arizona
doing donuts in calibration mode! :unsure: what will they think of next!
Great excuse when chucking a skid.... "Excuse me officer, I was just calibrating my mirror." "Sorry for the smoke..., that is what the manual said."
