No problem with airflow to the radiator with that set up.you think you have missing parts, I'm missing the upper middle of my bumper.....😀
I am sure my current #6 heads would work fine with tons of 6K blasts, screw in studs, guide plates, full roller rockers, dual springs, big valves and porting, the original cast pistons, not so much. I am swapping since that is not my intent with my 350. There is a 403 and TH350 but it is a far drive but is still tempting for the 88, the heads mentioned would be perfect.This is the main reason I decided to go Chevy in my olds. I saw 6k on a reg basis and sometimes higher. On my cammed olds 350 I got really good at swapping rocker guides lol
Oddly pistons were one area I never had issues with on my old olds 350. I guess its possible it had aftermarketI am sure my current #6 heads would work fine with tons of 6K blasts, screw in studs, guide plates, full roller rockers, dual springs, big valves and porting, the original cast pistons, not so much. I am swapping since that is not my intent with my 350. There is a 403 and TH350 but it is a far drive but is still tempting for the 88, the heads mentioned would be perfect.
