So ... this is the rough plan of where I'm wanting to go with my Cutlass over the next 18-24 months. If any of you have any suggestions please feel free to put them in here.
Purpose:
Corner carver/Auto-x/Drift/Mean Daily Driver
Engine:
Olds 350 or Chevy 350 with F.I. conversion, or LT1 or LS1 (around 350 - 400 rwhp goal). Headers, X-pipes, 40 series Flows. Vortech supercharger at some point in the future.
Transmission:
5 or 6 speed with www.crossmembers.com dual exhaust transmission mount, ACT clutch upgrade, lightened flywheel.
Suspension:
SC&C Stage Two or AFX front setup, Watts rear, Currietrak control arms, poly bushings, Bilstein shocks with Global West springs or Coilovers done by SC&C. Spohn sway bars, SPC tubular control arms. Custom driveshaft, 12 bolt or Ford 9 inch rear end with 4.10's and limited slip. 13" brakes front, disc conversion rear, proportioning valve, hydraulic rear brake controller. Install quicker ratio steering and try to get a few more degrees of steering angle out of the tie rods. I'm sure SC&C will have an idea for that.
Exterior:
Dark gunmetal gray metallic, fiberglass hood/trunk lid/fenders, carbon fiber (CF) side mirrors, CF rear spoiler, Lauren Engineering rocker set with 442 style front spoiler, FE3X style fender flares, blacked out trim/grill/bumpers, HID projector lights, LED conversion to rear, remove lower rocker factory trim, tinted windows, 17x9 (f) 17x10 (r) mesh rims wrapped in Falken rubber.
Interior:
All black (carpet, dash, headliner, doors, seats, etc), Sparco race buckets with Crow harnesses, 10 pt. roll cage, Race pack digital dash, CD - Flash drive player with mild upgraded speakers, Sparco steering wheel – pedals - shift knob, B&M short shifter, CF trim on dash.
I dunno ... that's where I'm heading with it in the next year and 1/2 or so ... I'm still trying to do as much research on the suspension as possible b/c that is what is giving me the worst headache. So what do you all think? I hope I should be able to pull this off for around $15k give or take $2k or $3k.
Purpose:
Engine:
Transmission:
Suspension:
Exterior:
Interior:
