Okay so I was thinking after I posted the 4bt Powered A Sedan that maybe I should start something for "odd rods" hot rods built from not so mainstream cars... or mainstream cars with not so mainstream powerplants... But lets see where this goes, I'm sure some of you guys have something to add so add it! Theres got to be a few G's out there with odd powerplants too! anyways here goes....
How about a couple hopped up Gremlins, and a Spirit
http://www.hotrod.com/featuredvehicles/hrdp_0908_amc_drag_cars/index.html
or maybe a '22 Ford Depot Hack with a Jag 6 (so f'n cool)
http://www.hotrod.com/featuredvehicles/hrdp_0912_1922_ford_depot_hack/index.html
What about an LS1 powered Citroen?
http://www.hotrod.com/featuredvehicles/113_0703_1966_citroen_id_19/index.html
May I suggest a turbine powered GMC Pick Up?
http://www.hotrod.com/featuredvehicles/ ... index.html
Not totally bizarre but insanely fast.. an 8 Second Eagle Talon!!
http://www.hotrod.com/featuredvehicles/hrdp_0401_1991_eagle_talon/index.html
An ex drag car Hudson!
http://www.hotrod.com/featuredvehicles/113_0306_1941_hudson_traveler/index.html
The Ultimate 1,000hp Turboed Camaro.. Toyota Powered, and totally wicked!!!
http://www.hotrod.com/featuredvehicles/hrdp_0904_1967_toyota_powered_chevrolet_camaro/index.html
Maybe an LS powered IH Scout trips your trigger...
http://www.hotrod.com/featuredvehicles/hrdp_1001_1962_international_scout/index.html
Or how about this nose high '55 Olds Gasser, complete with 394 Olds Power!!
http://www.hotrod.com/featuredvehicles/hdrp_0610_1955_olds_88_gasser/index.html
When you think of the fire breathing dragsters of yesterday the name Baracuda probably strikes fear into your heart, but do the names Studebaker and Packard make you cringe just as much? If not they should. Check these out!! The Flinstone Flyers!
http://www.hotrod.com/featuredvehicles/hrdp_1002_flintstone_flyers/index.html
What do you think about a Toyota Corona?... What if it's powered by a V8 and built to go FAST??
http://www.hotrod.com/featuredvehicles/113_0603_1968_toyota_corona_unorthadox_hot_rod/index.html
Can you say no to a chopped mid engined V-Dub Bus? I don't think I could...
http://www.hotrod.com/featuredvehicles/hdrp_0603_1962_vw_bus/index.html
This may be over the top...but it's pretty mean, even if it is a Volvo....
http://www.hotrod.com/featuredvehicles/hrdp_0407_volvo_t6_roaster/index.html
When most think Plymouth they probably think Mini Vans, or Hemi Cuda... When I think Plymouth I think Sox & Martin... The Sox & Martin Altered Belvedere... With Hemi power to boot!
http://www.hotrod.com/featuredvehicles/hrdp_0907_1965_plymouth_belvedere/index.html
For you G-Body Guys... A Formula D Caballero!!
http://www.hotrod.com/featuredvehicles/hrdp_0412_1986_gmc_caballero/index.html
Maybe a Big Block 4spd '71 Dodge Wagon?
http://www.hotrod.com/featuredvehicles/hrdp_0908_1971_dodge_coronet/index.html
Does a seriously built Pantera float your boat?
http://www.hotrod.com/featuredvehicles/28518_1973_de_tomaso_pantera/index.html
Did Ferrari build a mid engined wagon? No, but this could change your veiw on your grandma's Rambler
http://speedhunters.com/archive/2010/01/29/car-feature-ultimate-misfit-the-ferrambo.aspx
and last but not least who woulda thunk an old Ford would get converted to AWD? or be powered by a turboed Volvo 5cyl?
http://www.hotrod.com/featuredvehicles/hrdp_0905_1932_ford_coupe/index.html
I'll post some more in a bit...
