Throttle Cable and Transmission Kickdown Bracket
markcp
106
I'm running a Performer EPS Manifold and Edlebrock 600 CFM carb. What have you used for a bracket for throttle and kickdown cables? I bought a two piece adjustable bracket from Summit, but even slightly modified I can not get it at the right angles for clean straight alignment. It is a SBC 350 with 350 transmission. Thanks Mark
I have a nice one from TCI that I was going to use with mine. I swapped the Edelbrock for a Quadrajet though before I used it, so now I just use the stock bracket. Stay away from adjustable BS brackets unless maybe you get one from Lokar. They always come out of adjustment and wind up being a losing battle. My TCI bracket is ugly, but it is a one piece stamping and about 3/16 thick, so it won't flex. See if you can get one of those as it changes the geometry to work with the TV cable used in most G body applications.
