A friend painted himself into a corner by useing dropped spindles. Now the tie rod ends hit the expensive Centerline rims. For now he is useing spacers to get the rim away but can feel the stress on his front end. He thought he might reposition the tie rod end above rather than below the steering knuckle, until I reminded him the stud and hole are tapered. I'm sure there are tie rod ends with larger diameter studs that can be used once the spindle holes were re-reamed to fit from above, but would that then upset the steering geometry? He also said the off-roaders use a kit that has a tapered insert that fits inside the drilled out spindle to adapt to an above mounted tie rod. Seems like a lot of work just because he's too stuborn to realise he screwed up.
