How much timing should I run on a 1972 350 Olds engine?
The engine is basically stock with a Edelbrock intake,1406 Edelbrock carb ,HEI distributor,Hedman headers and an aftermarket cam of unknown brand/size.
The base timing now is 12 degrees and about 30 degrees at 2500rpm,is this too low ?
It seems like it runs ok,but I don`t have much experience with timing ,so I am not sure if it`s too low or not.
