I know might be a bit pricey, yet would be good idea to get a boresight camera down the hole and look at the gear on the cam. I just looked at the harbor freight unit, $84 here in Arizona.
Typically once gears start to wear they will continue to wear in the direction and method of the previous problem. So you can go with the melonized or a bronze gear, as the melonized is suggested but if the cam gear is bad or damaged it will continue to wear as such.
