great answer!dogshit said:With what rim? 14x6, 15x7, 15x8, 16x8 etc. Regardless assuming backspacing is ideal it comes down to tire height and section width.
I know you can run at least up to 27 tall up front with a section width of at least 9.5". I use a 235/60/15. In the rear you can run at least 27 " tall with a section width of 12.2" 28" tall with a section width of 11" or 29" tall with a section with of 10.2. Slightly larger may fit depending on backspacing and some variance from car to car. Those are 295/50/15, 275/60/15, and 255/70/15. With a small frame notch you can easily run 295/65/15 a 29" drag radial and I have seen 315s but than may have had fender wheelwell clearencing etc.
dogshit said:Get 15x7 up front 15x8 rear. 235/60/15 stock height for performance gbodys with a 275/60/15 in the rear.
