hey guys i was looking to give my monte a more agressive stance and i was wondering would there any way to put 275mm tires on the stock rims?(i believe i have 86 SS15x7 rims) if not then whats the widest tire i could run on those rims?
ok thanks dogshit, do you know of anyone who has cut the rims and added like 2-3 inches and weld them back together?dogshit said:You can get 275/60s on but 255/60s is a better fit.
ok ill check that out...ive seen 16x8 custom SS aluminum rims for 380 each and then the 16x10 is 420 each and thats pretty expensive for one rim loldogshit said:Yea they cut your centers out then weld them into a new rim size of your choice. I did it with two of my factory GN wheels and two of my 442 factory wheels as seen in my pics. Mostly ran 275/50/15s & 275/60/15s both drag radials for my desired gearing and look. But at one time I planned on notching the frame to run 295/65/15 drag radials for behind the 509ci.
Never wanted my stuff to look like a drag car but always be ready to make the guy with pizza cutters, obnoxious loud turns downs, and a monster tach on his dash look stupid. Here is a few;
http://www.stocktonwheel.com
http://www.fixrim.com
http://www.weldcraftwheels.com
But if you have the factory aluminum SS wheels I don't know what they are able to do if anything.
