top ten list of parts
All the hardware to restore a regal tail light screws,clips,etc. The bolts that hold those pieces just above the rear tail lights. Bucket seat trim pieces( one is broken :x, and I think there are more pieces missing). the bolts that are right beside the grill for the front fillers. Bucket seat passenger side seat belt buckle. Riviera low fuel indicator U41( I ripped apart 4 and none had that option. :x ) Pull strap screw covers. Every day that I work on my regal I always find something else I need. :mrgreen:
Always all the power seat stuff .seat harnesses, harness to dash ,seat switches, seat side panels with switch cut out . tracks ,
And the hard one . The reinforcing backer that is in seat for where switch goes.
The 2-door Malibu filler pieces, between the rear side panels, and the rear window lower panel. Very hard to find they always break in half. You'll have to take the back seat out to get them out intact.
78-80 cutlass body filler pieces both fron and back. If you get any let me know I need most of them
Oh I forgot the third brake insides. The part that is chrome plated. I opened up like 4 cars the bottoms were cracked cause some :blam: Tried to pull out the harness when changing the bulb.
Power dock lock mechanical parts. The little springs that retain the manual lock rods to the power actuator. No one has these parts. Not even Dorman :shock:
Top of my list is 78-80 Cutlass Supreme rear bumper in nice shape..
Burgandy Cutlass drivers side A pillar moulding
78-80 Cutlass drivers side head light bezel in nice shape... a rock was nice enough to take out a peice of mine the other day, I kinda wish it would've took out the light instead..
AC delete peices (heater box, glove box, the switches, all that stuff)
All the bracing peices
non faded burgandy lower door panels for Cutlass
oh a non cruise throttle cable (so I can ditch the cruise sh*t that doesn't work) or cruise stuff that works...
non vinyl top 1/4 windows for 78-80 Cutlass, and rear window trim
78-80 Rocket trunk lock bezel (it was a dealer deal I think)
Stainless roof trim (dealer deal)
Burgandy Sport steering wheel
and all the peices for a manual Cutlass (shifter, brackets, clutch pedal assembly, floor shift column, trans, etc.)
Burgandy Regal concert sound door panels w/ speaker grilles
Just some of things I could use someday..
the b pillar part that holds the weather stripping on elkys. a grille that fits a 78 elky thats not rotten or broken.
Oh here is something I think that might be missed. The 3 little rear glass retainers that are under that metal panel. Mine broke, but some guy parting out his regal gave them to me. 😀 Also that press board that covers the rear shelf. Mine got leaked on and I'm debating if I should just prime it replace it, or seek an abs/custom replacement.
sorry i been away so long been busy but i been into the series II cars but ill be bringing more stuff on for the gbody cars. stay in touch
