+1 on what Hurst Olds stated. The physical condition of the fastener is just as important as is whether or not some type of lubricant was used on the fastener threads. MFGR's like ARP provide their own special lube for use with their fasteners so that the demanded torque value, when established using a torque wrench, will be correct.
Where things change is if you use an offset adapter instead of just an extension and 6 pt allen socket. For purposes of this discussion, torque adaptors are not those couplings that you use to change from one drive size to another. They are actually a specialty piece that allows you to have the driver or wrench out in the open while still being able to access the nut or bolt or screw that is otherwise somewhere where it can't be reached easily. Snap On is one example of a Mfgr that offers them, and the ones in my roller box are 3/8ths drive by 1/2 and 9/16ths by 12 pt hex ends. Crow foot wrenches are another example of this that gets uses when a gas or hydraulic fitting can't be accessed directly.
If the situation demands one of these be used with a torque wrench, be aware that it changes the final value of the torque that is delivered to the fastener. The dial or indicator on the wrench will display the desired value when the torque is applied, but the actual torque at the fastener is greater. Because of the use of the offset adaptor, the torque is no longer being applied in a straight line, What the offset adaptor does is to increase the leverage that the torque wrench is applying to the fitting or fastener. There are actually tables and formulas that can be used to calculate display vs actual and how much less torque needs to be applied by the wrench due to the greater leverage to get the correct amount. at the bolt.
I use both Snap On and Gray Tool torque wrenches and they came with instructions including how to calculate corrected torque value based on the length of the offset adaptor.
Might be a You-Hoo Video somewhere that explains it all in pictures
