With a setup like that I'd go with at carb. It's a lot easier, and you won't sacrifice your top end. If you build up a 355 you'll want a good 5500 RPM powerband at least! I'd spend the money on heads and not worry about TPID's350GP said:Motor wise I plan on keeping it about 355ci, and buying some heads that will bump up my compression alittle bit (9.5-10:1) and flow alot better. Together with a decent rear-end, and maybe drag radials. But to tell you the truth, I hadn't thought about how TPI would effect my ET's with it's lackluster top end performance. I probably need to make up my mind on just what role this car will play, or when im "ever" going to get it runnung!
