Anyone who has followed my build/posts knows the amount of bullshit I have been going through just to drive this car. To keep a long story short my transmission only leaks when the engine is running. If I mop up the floor and let it sit it will not leak. As soon as I start it up I have a leak. The front and rear seals look and feel dry, the pan is dry almost all the way around until the front and passenger side. Up by the dipstick tube is wet even though I used a fat o ring and rtv because I had it leaking before the converter change. What's the deal with this damn thing? Any ideas? I check the fluid and it seems to be in the ideal range. Trans maybe has 10-11 qts and its a deep pan.
And yes I checked the vent, it's dry.
