I am looking at a '86 442 that I found on Craigslist, I really love the look of the car - black on top, silver on bottom, T Tops, leather seats with 442 on the headrests....
Anyways, gas mileage is not a huge concern to me, but I do want to be able to afford to drive it, which leads me to my questions.
The description says that it has Edelbrock heads with 2.02 valves, 510 lift cam, headers and 3" exhaust, 3000 stall, TH350 trans and 4.10 gears in the rear.
I am thinking that this thing would be cranking around 3,500 - 4,000 RPM at 70 with that TH350 trans and the 4.10 gear. If I get the car, I would like to lose the TH350 in favor of a TH700R-4 to get overdrive and the lower first gear, not that I would need it with the 4.10 gears :lol:
I know a different driveshaft would be needed as the 700R-4 is longer, and the crossmember would likely need changed as well. Is there a bolt in crossmember available for the 700R-4 for a G Body?
It would be my daily driver in the summer, and would like to get at least 13 MPG out of it as that is about what I get with my '94 S10 Blazer with a 350, Trick Flow top end kit, and 33" tires.
