Looking for the lower bracket from a 2004R transmission. I have an 87 Cutlass Salon and need this lower bracket.
And this lower bracket bolt
Bolts to the transmission pan and holds cable.And this lower bracket bolts up to....?
That bracket is different on the BOP cars from my experience, we have repros on the shelf for $9.95 for the Chevrolet or the BOP configuration, the difference being the cable opening.GM p/n 10027568. Discontinued from GM.
cable spring clip is p/n 470779. Discontinued from GM.
SHIFTER CABLE BRACKET ,4 SPD AUTO 78-88 GN 442
Shifter Cable support Bracket, for 4 speed Automatic , MW9, THM200-4R OE# 10027568 , mounts on pan Fits: 1978 1979 1980 1981 1982 1983 1984 1985 1986 1987 1988 Cutlass 442 Supreme Hurst Grand National Regal T-typewww.chicagomusclecarparts.com
Thank you for yor help!That bracket is different on the BOP cars from my experience, we have repros on the shelf for $9.95 for the Chevrolet or the BOP configuration, the difference being the cable opening.
Thank you for yor helpThat bracket is different on the BOP cars from my experience, we have repros on the shelf for $9.95 for the Chevrolet or the BOP configuration, the difference being the cable opening.
Its Olds but thanks for that also future purposeYes, they are different. That's why I pointed you to the Oldsmobile part number.
If you have a Chevy 200-4R, you would use p/n 10026014 instead.
