How much fluid does it take to fill a turbo 350 transmission it has a TCI pan,also how much in the stall converter/transmission any idea? thanks, Bryan
I usually fill the converter first....if its stock size it will take about 2 qts where you can install it in the trans without it spilling out.....I usually have 10 qts in a stock panned trans total including the converter. with an aftermarket pan you can usually find out from the manufacturer how many more qts it will hold over stock.....I usually put in 9 qts and run it through the gears and let it get up to temperature then check it.....10 is about the max for stock pan trans
