I had a bad transmission leak, but after replacing the transmission gasket, the leak stopped (temporarily). A few days after replacing the gasket, I noticed a puddle of trans fluid on the garage floor. Any ideas on where the leak could be?
Could be anything. See where it's coming from. Go under and clean all fluid and check next day where it's coming from. That is the only way you can tell.
4 places it can leak from....front pump seal...rear tail shaft seal...pan gasket...and the shifter seal....and maybe the tv cable housing if you have a 4speed. Most of them leak from the front pump or the gasket and sometimes (rarely) the coolant line connections.
