transmission question
krazykyle
283
does any one know which is the supply line and the return line on a 350 turbo transmission.
Its the bottom line in the rad. leave that connected to the rad disconnect the top one and connect the cooler to the top port in the rad and the return line from the cooler to the return line to the transmission. gotta run it thru the rad so the fluid will get to opperateing temp.
