Transmission swap
MWA
129
MCDonough,GA
Can you hook up an 700R trans to an 350 oldsmobile? Can it be done is it possible?
The 200 4R will.
Doug
which on is better the 700r or the 200r? Does the 200 have an overdrive? 🙁
The TH200 is a three speed. The 200 4R is a four speed overdrive. IMO the 700R4 with a rebuild and a Trans go shift kit can be shifted at any RPM . Th200 4R needs a few hard parts and still will shift out of first gear at 4200 to 4500 RPM.
200r4 or 2004r as some know it as will outlast a 700r4 if you do some hard parts. Also if you do the brf valve body and gov the shift points will be around 5300-5400 rpms. Ckperformance makes duplicated brf valve body and gov.
