Trimming a valve cover gasket?
slappnutz
42
22
8
So i'm having a debate if i should attempt this or if its even a good idea. 350 sbc with vortec heads, center bolt covers. I have to run a double thick gasket for clearance. Old one was leaking bought a new set of felpro dbl with metal gasket in the middle. Here is my dilemma, its a little to snug to fit in the valley without trimming the inside corners a bit. I'm thinking a dremel with a sanding wheel to shave off a little bit to make it fit properly. Anyone have experience with this? i searched the forum and google with not a lot of luck.
Clone TIE Pilot
3,531
2,122
Galaxy far far away
Are you using the Vortec specific valve covers and gaskets or the pre Votec centerbolt style valve covers and gaskets?
slappnutz
42
22
8
something similar to this. not the greatest but they do the trick.
slappnutz
42
22
8
The rockers fit fine. It’s the actual cork gasket that doesn’t fit in the valley.
John Canon
Apr 19, 2022
75
45
Vancouver Canada
I would use an Exacto knife and a cutting mat or flat piece of wood. Use an ultra-fine Sharpie marker to draw the line, then the Exacto knife to cut gradually deeper and deeper until done.
slappnutz
42
22
8
That’s kinda what I was thinking but it has a metal gasket sandwiched between the cork. That’s why I was thinking a dremel.
Streetbu
Know it all, that doesn't
May 22, 2011
3,590
10,936
Central NY
Personally I would run the blue rubber gaskets that the valve covers come with originally. JMO
Clone TIE Pilot
3,531
2,122
Galaxy far far away
If you cut the cork gasket you will expose the shim core which can allow oil inside the gasket and eventually cause leaks. I guess you can seal the cut corners with RTV. I have not seen SBC valve cover gaskets with such thick corners. Generally, I use steel core rubber valve cover gaskets instead of cork.
565bbchevy
9,362
12,018
Michigan
I only use steel core rubber valve cover gaskets.
