So I have the Hotchkis upper A arms to use with the GM B-Body spindles to get the 12" rotor upgrade. With that said, I've been looking at the UMI lower control arms. They come in regular ball joint and 1/2" taller which "improve spindle height, lower center of gravity and reduce bump steer"
Here's the question. Can the 1/2" taller ball joint lower arm be used with the B-Body 12" rotor conversion?
I have the BAER adjustable bump steer tie rod ends, as I've been told that the B-Body spindles throw off the tie rod end angle. I'm wondering if the 1/2" taller ball joints would help with that.
Hutch
Hutch
