1. Removal: Remove upper control arm assembly from car
2. Remove nuts from ends of pivot shaft
3. Position control arm assembly and tools and pushing bushing out of control arm.
1.To install bushings, place pivot shaft in control arm and push new bushing onto control arm and over end of pivot shaft. On "G" series models, both upper control arm bushings are to be installed 13.3 +/- .5 mm from the face of the control arm to the bushing outer sleeve.
2. Assemble nuts to ends of pivot shaft
3. Install the upper control arm assembly
