Hey guys, looking for a little advice. 87 cutlass, 383 stroker with vortecs. Swapped the old rusty headers out for some new afterburners a couple months ago and had a pretty serious contact issue with the passenger side A arm. After closer inspection I noticed the motor mounts were looking pretty rough. Ordered the Energy suspension poly insert kit with the trans mount for an 87 monte 305. Got the mounts out, drilled, and the inserts put in. Started to bolt everything back up and noticed that the driver side didn't look like it was gonna bolt up. The ears on the inserts were binding on the engine side of the mount. Got the passenger side bolted up pretty easily. Got the drivers side bound up a couple times, and after a lot of cussing, ended up cutting the ears off the inserts. After cutting the ears off, the engine side and frame side will slide together, but the center hole is about an inch and a half off. I pull the frame side off and run the center bolt through. Lower the engine and the holes are way too high. Same clamshells, same engine brackets, the inserts are installed correctly with the bigger ear side toward the wider spaced holes on the baseplate, and the mount isn't upside down. Anyone run into this before? Options seem to be try to drill the frame holes to match, weld the b*st*rd on, pick up another engine side mount in case the PO rigged some mismatched stuff together, shave the poly to slide it up and shim the low side to keep it from sliding, or push the car into the cul de sac and light a match... 🙂
