bigdan said:forgot to say that I have a genuine W31 engine sitting on a cradle that would love to nest in this car ! ;-)
Dan
That engine is worthless. Ill take it off of your hands for $50 bucks. :wink: :wink: :wink: :wink: :wink:
Dan
bigdan said:thank joe & all the others ....
the man says it has 255 HP and it is supercharged ????????????
the link says the 225 V6 had 155 HP no power adder at all
ill have to see !
joe_padavano said:srercrcr said:JOE IS 100% CORRECT. If memory serves me right, it was an aluminum block.
I'm afraid memory is the second thing to go, and I can't remember the first... :wink:
You are thinking of the aluminum block 215 cu in V8, used in the 1961-1963 Buick, Olds, and Pontiac compacts. The 215 is actually the same architecture (bore spacing, head design, front cover) as the Buick V6, but the V6 was always cast iron. The V6 was also released in 1961 (in 198 cu in size) but only offered in the Buicks for 1961-63. For 64-65 it grew to 225 cu in and was also offered in the Olds (still cast iron). As noted previously, the V6 design and tooling was sold to AMC for use in Jeeps in the 1960s then bought back by GM in 1975 after Oil Embargo #1.
85 Cutlass Brougham said:The earlier Buick V6 was not the same as the later one. The early one was based on the old Buick nailhead (or nail valve depending on who you ask) V8 engine, while the later V6 was based on the newer Buick V8 which came out in 1967 or 68.
