If you are taking off the body replace all the lines especially the brakes!!
Nobody was saying go buy some stainless tubing and bend and flare your own. You can get pre-bent/pre-made lines already in stainless. You just straigten them out and bolt them in. I believe everyone's painfully aware that making your own stainless lines and flares require a lot more work. Buying pre-made stainless kits are the way to go.Also, I know people will not agree with me here (maybe they will) but I have a reason for saying it... stay away from stainless lines unless you either have gorilla arms, or a hydraulic flare tool, and bending tool. Stainless is VERY difficult to work with otherwise! Fuel line is 3/8" and I've only worked with 5/16" and let me tell you that it was so hard to flare with a hand tool that I bent the solid metal rod in the tool kit doing it, and had to use a wrench for leverage. With normal steel likes you should be able to do this with your bare hands, and nothing to assist you with torquing it. Bending it with a hand tool would have been equally as difficult, but thankfully I did not need to.
HOWEVER THERE IS SOMETHING EVEN BETTER.
Back in my days as a parts monkey over at Pep Boys, we started carrying a new type of metal brake/fuel/transmission cooler line in rolls that was a nickle/copper alloy. It's strong enough to withstand the pressures of brake lines, is corrosion resistant, AND is very easy to work with (in other words, it flares and bends very easily). BUT it's not cheap! In my opinion though, it is absolutely WORTH IT.
If you can find them, then yeah they're awesome. But if you can't find them, or you need to modify them slightly like I had to do to my transmission lines in order to accommodate for a trans cooler... then yeah. I wouldn't buy them again, that's all I'm saying lolNobody was saying go buy some stainless tubing and bend and flare your own. You can get pre-bent/pre-made lines already in stainless. You just straigten them out and bolt them in. I believe everyone's painfully aware that making your own stainless lines and flares require a lot more work. Buying pre-made stainless kits are the way to go.
