vaccum can line help
Are you referring to the front vacuum break actuator?
The vacuum feed port is a short hose nipple located at the front, outboard edge of the main carb body.
Ok let me re-ask this question ,im going through my engine swap and the engjne is running good it seams but im not getting vaccum out of ,distributor, or front of carb im not feeling any suck from these lines,so i started looking around and the black vaccum can up by the front fender i dont have it hooked and im not sure where to run the line from the can to on my edelbrock carb.
