Vacuum advance. To port or not to port?
IMO, I think the only way ported would work better would be if the timing curve ( and vacuum advance cannister ) was set up specifically for it and the result would be sleightly more throttle response. If you had your distributor curved properly and with the right vacuum advance cannister, then I say manifold vacuum wins because of the better idle and milage. I say better milage because I would assume the throttle is light enough during cruising where ported vacuum may not have even kicked in yet. Again though, maybe some carbs are calibrated differently so...
Overall I would say that this topic has caused many debates ( and arguments! ) over the years so in the end you just have to test it for yourself. I personally never noticed any advantage when running ported vacuum but have noticed the obvious disadvantage of having much poorer idle quality and the engine runs a tad hotter too. Running manifold vacuum fixes that and my throttle response stays the same so it was an obvious choice for me.
this post brings up another question....if you are running a TCI lockup kit, which source of vacuum do you use for it?....(final jeopardy music) :rofl:
Ported for sure.
DoubleV said:
Now here's something I've never heard anyone do; what if you ran both ported and manifold? You'd always get the vacuum that the higher of the two would provide at that instant. Probably wouldn't be able to get the curve right to run with both but perhaps one could.
I think some smog-era Fords may have used such a setup.
I believe there may have been some sort of check valve(s) in the mix tho.
Always meant to look into it more ... as I always liked the idea of the middle ground compromise.
Better cooling at idle is never a bad thing & IMHO the advanced timing at idle makes for a nicer exhaust note as well.
