Vacuum hoses
69hurstolds
7,842
16,558
*sigh* Because there are pretty much no other colors you need to worry much about under the hood, I'll answer this one.
On a typical G-body, Gray goes to the water cutoff valve. Purple goes to the manifold vacuum.
  • Winner
nycutlass
573
120
NY
69hurstolds is the gray water cutoff valve controlled by the inside levers ?
69hurstolds
7,842
16,558
Yup. I haven't looked at it in 100 years, but basically, when you go from cold toward hot (as soon as you come off COLD) with the temperature lever, it applies vacuum or releases vacuum to the valve depending on the setup to open the valve to allow water to flow through the heater core. When you are in MAX or all the way COLD position with the A/C, the valve applies/releases vacuum to close the valve to stop flow through the heater core.
