I am wrapping up an LS Swap on my Gbody and have some questions about the vacuum lines. I am not running any of the stock emissions stuff which I know these used to connect too. So my question is what should I do with them. I have read multiple responses and it seems to be matter on what components you have so I wanted to ask and see what you guys think.
From what iv'e read it seems like the two circled in red are supposed to connect all though i could be wrong and then I need to know what to do with the other three, some say I can just cap them off but I want to make sure!
This is a top down image of the 5 vacuum ports I am dealing with. The driver side valve cover is under my wiring, in the middle of installing that so sorry for the mess.
These two i have read I can just connect with some heater hose but I want to be sure
This is the passenger side port on the intake and I am unaware of what to do with this or the next two images below
This is the port on the left side of the intake
And this is the port on the driver side valve cover that was covered earlier
Hopefully it's simple and i am just overthinking it but I just want to check before i do anything!
I will also note I am not running a catch can and the block is an LM7 with stock internals
