"stage 3 4 bolt Buick 455"From a reliable source who worked at Olds at that time, with 8 to 1 compression, .400 lift cam and single Qjet, 400 hp. It was 650 hp with compression and cam. Huge ports and a heavy duty 4 bolt block with the cam raised. It was supposed to debut in 67 for the 442 but pushrod issues prevented from coming out at that time, raising the cam fixed it. When it was supposed to debut in 71, chevy threw a tantrum like a spoiled child and with the upcoming issurance rate hikes, that sealed it's fate. The Stage 3 4 bolt Buick 455 was other almost that should have happened.
There are few in existence like the W43. The Stage 3 455 was probably closer to reality than the W43 but I believe the timing was the issue with it as well. The 70's was a buzz kill for car owners.
