maddog20_20 said:Buy a $60 mini spool from Jeggs and call it a day --- 😀 Takes about an hour to install in an open rearend and the you can have a two tire frier instead of the single.
yup yup but if you get a really good deal on a series 2 carrier jegs n summit sell series 3 ring n pinion gears for a siries 2 diff. I have 4.10 richmond gear for a 2.41 factory limited slip unit don't know if i gonna use it tho... where u outta maybe I'll sell.pontiacgp said:what gear are you using cause then makes a difference in the carrier you need....3.08 and down is a 2 series and 3.23 and up is a 3 series
