Just some info for you guys...DO NOT put a mechanical clutch fan with a spacer on the GM Serpentine belt system. Just snapped the pulley and fan right off my water pump.
Same with hundreds of thousands of C/K and S/T trucks since the '80s.tc1959 said:Cadillac ran a fan and fan clutch on the Brougham with a 5.7 TBI and a serp drive . If I remember correctly it had a Fan blade and fan clutch that was set up to run the same direction as the reverse rotation water pump.
